Can you 'lock' cells like in excel?
Steve Mackay
You indicated in your reply below that if I wanted to vary the cost of an aircraft due to price increase I could export to excel do the math stuff and then import back to LPro.
However you said that if any time changes in an entry then LPro will re-calculate aircraft cost. Do you actually have to modify the time to a different time? ie If I go to an entry that was 1.5 hours and re-enter 1.5 hours will it recalculate at the latest aircraft cost?
If so is there a way to lock cells to prevent accidental changes occurring?
Cheers
Steve
Steve,
Give it a try, changing the values of the Duration and see on a 'test line' what happens.
Always make sure you do a backup (File..Archive..Backup) prior to test flying your ideas! /forums/emoticons/smile.gif
I tried it and just by putting the cursor in the box the value isn't re-calculated but if you re-enter your flight time it does re-calculate.
Is there a way to lock cells like in excel to prevent unwanted screw ups?
Sorry, you did ask that, I usually don't miss, good thing I fly with my non-typing hand! /forums/emoticons/smile.gif
No, unfortunately there is no way to lock the cells, however, I haven't heard of anyone having a problem with this.
I might not make any screw up like that but then I might. Belt and braces is sometimes worth it.
It is not a big issue, I just wondered.
Steve
