COD AKA Standup's
cts
The current (at leas the ASA part) does not properly track standup's. A stand up is imported as a 1 day trip when it is actually a two day trip. One leg at night (day 1), the next in the morning(day 2). Currently the program logs it as one day, thus not properly recording into Logbook pro when the trip actually took place, not tracking overnights (STD rate or CONUS), and tracking 30/7 rule.
CTS
CTS,
Most Standup Trips (This is not an ASA trip) have a marker for day one and day two (See Bold in Example):
D2031 D A I L Y BSE REPT: 2012L OPERATES- APR. 04-APR. 30 Mo Tu We Th Fr Sa Su
Base/Equipment: DTW/ARJ CA01FO01 -- -- --
4 5 6 7 8 9 10
1 3460 DTW-YUL 2112 2259 0112 0259 147 141 701 COD HILTON MONTREAL (XXX) XXX-XXXX SHUTTLE
2 3461 YUL-DTW 0600 0805 1000 1205 205 202 352 0 17 400 1 1223 18 19 20 21 22 23 24
D-END: 0835L -------------------------------------- 25 26 27 28 29 30
TOTALS BLOCK 352 DHD 0 CREDIT 400 T.A.F.B. 1223
The trip is a standup, cod, or highspeed and should be stored on a single logpage. Change 2 on the second leg to a 1 (See bold in example).
For example:
D2031 EXCEPT BSE REPT: 2012L OPERATES- APR. 04-APR. 30 Mo Tu We Th Fr Sa Su
4 5 6 7 8 9 10
1 3461 YUL-DTW 0600 0805 1000 1205 205 202 352 0 17 400 1 1223 18 19 20 21 22 23 24
Then import the corrected trip.
Fly Safe!
Paul Auman
ASA trips have the day instead of #'s. For example my paring says MO, TU, instead of 1, 2. Do I change may paring to MO, MO?
CTS,
In this case change the TU to MO and it will import on one logpage.
You can send me a sample trip to support@nc-software.com, and reference topic 1974. I will send you the adjusted trip back if you have a problem.
Fly Safe!
Paul Auman
