Erroneous Reports
ckole
For some reason some garbage data has been inserted into my application. In turn I am getting erroneous reports each time I hotsync. Examples below... How can I correct this? I try to go to those dates to see if any pairing exists but I don't see anything.
[*]AirlineLog-201912
[*]AirlineLog-202109
Chris
Chris,
These files are created when you import a trip to an incorrect date or the date is incorrect in the imported paring. To remove:
Hotsync.
Make a backup copy of c:\program files\palm.
If you are using a newer PDA with Palm OS4.5 or greater you can tap (applications)(menu)(delete) and then delete AirlineLog201912 and AirlineLog-202109.
Hotsync.
If you have an older PDA, or OS prior to OS4.5 please create a support ticket under (Support)(Support Center) from this webpage.
Fly Safe!
Paul Auman
APDL Development Team
