ExpressJet
Found a little luck importing. I had been trying the "Generic CrewTrac Sabre System" import filter selection on the online Schedule Importer without any luck, just errors. I just now tried the "Generic Crewtrac Bidlines (PDF)" selection on the Import Filter and got it to import. Here's what I went through:
1. Log into Crew Trac via xjt.com
2. Select "pairing print" on the left under Options
3. Enter your pairing number and date and submit
4. Select "show printer friendly version"
5. Copy everything on the pairing, beginning at the pairing number and highlighting all the way to the end of the T.A.F.B line (go past the end of the T.A.F.B. numbers)
6. Paste this information into the online Schedule Importer, Import Filter, using the "Generic Crewtrac Bidlines (PDF)"
7. Click "continue" to import
8. Follow the rest of the instructions that appear
For whatever reason, my 4-day pairing showed 5 days. Day 1 was blank. Day 2-5 were the correct 4 days. When I imported it to my Treo 650 and ran the APDL program, it asked me what day to import the pairing. After trial and error, since there were too many days on the pairing, and the first day was a blank day, I simply chose to import the pairing one day early. I then selected edit and delete the logpage for the blank day. Another issue is that it did not import the pairing number into the pairing number field. It put a portion of a date stamp in the pairing field, so I had to edit that and hand-enter the pairing number on each day.
