General data loading questions
F'edbyDAL
General questions?
Is there a way in the analyzer to eliminate columns or move them out of the way like you can in spreadsheet so to not need to move the scroll bar at the bottom to verify column inputs?
In analyzer mode there is columns for MEL, and AMEL. I have light twins in AMEL but not in MEL and vise versa. I have the aircraft set up the same as well as the autofill to use as a multi engine aircraft?
D
Yes, you can right-click on the Analyzer and choose the Display...Configure Display to hide columns. They cannot be rearranged. AMEL is from Options...Aircraft, did you add MEL as a custom column or redefined column header?
