Import issue
whiskeypilot
I have tried multiple different ways to import APDL into LBP. I'm getting hung up on the times converting. It its not converting the times from minutes to Hours.tenth. I've tried to do both CSV and TAB. I've tried all three time options. I am using the bata test for APDL. Also, my approaches are not logging correctly from APDL. Showing 0 on the spreadsheet but 1 or 2 etc. on the app.
See the after import picture below, tarting with thse 11th.
When I select MM and finish the process, no flights import. The only options that import are Hours.Tenths and HH:MM. Both of those selections do not import correctly. I just tried MM again. When I go back into my LBP, the last flight is on the 4th, showing none of them actually imported.
If you can't get it to work then open a support ticket and include your export file. I see no reason it's not importing as long as you have mapped the min required fields of Date, Type, Ident, Route, and Duration (or SIM).
