Logged Input pop-up menu’s a little lower please
pjsieders
do not know if It’s mentioned yet, or noticed by your team, but when the input windows show up on the screen in landscape view, you cannot see the top of the menu Window ( see picture attached). You are not able to hit the cancel, or save buttons. In Portrait view, it’s fine.
Can you move the menu window just a little lower so it also works in landscape view ?
thanks,
Patrick
@pjsieders I can't reproduce this on my iPad 11 running iOS 13. Can you still reproduce this? When you open the leg editor is the iPad already in landscape orientation or are you rotating the device once the leg editor is showing?
Are you running iOS 12 or 13?
What exact iPad are you using?
Please go to the Communication area of the menu in APDL and submit a problem report so we can get more info about this device.
Thanks Neil..
I still have the issue though..
I am normally working in landscape mode, then it still cuts off the upper line ,and I have to rotate to unblock so I can edit.
I hope that you can duplicate.
Patrick
