Installation Error
dagerlach
I'm still struggling to get LP running. I have installed the latest SW from Dell, hard rebooted, soft-reboted, and here is were I am. On my last attempt I recieved this error message: "The process cannot access the file because it is being used by another process."
Upon trying to run the LB app in the PDA, I get the following error code: -2147467259 Description: Form was unable to load.
Any chance you have thought about what might be a possible cause/work around?
David A. Gerlach
David,
What device and OS are you using? Is it on the supported devices list?
I am running a Dell Axim A05with Windows Mobile 2003. I have the most current version of Booster running.
I have just reinstalled the latest build of Appforge with no luck. I still recieve the error message and then the next note is to contact the author.
David
David,
The only thing I can suggest is a hard reset on the PDA. Ensure you are using ActiveSync 3.7 from Microsoft (free), and start from scratch on the install. There are others using the Dell Axim with no problems, so I'm not sure what may be the issue with your config.
I did the hard reset and reinstalled everything after I upgraded the Dell Axim from A04 to A05. No luck still says there is another application, which I assume is Data-on-the-Run using the database files. Any chance you all would download Data-on-the-Run and see if you also have the same conflict?
I have removed Data-on-the-Run now. Removed AF & LBP, reinstalled the two. During the Database Conversion, I get a dialog box that says the Database Conversion Failed. 'The process cannot access the file because it is being used by another process. An error occured when converting a Microsoft Access database to a Pocket Access database. To see details, choose the Show Log button.
I have removed everything now. Any ideas?
Well, now I performed a hard reboot of the Dell. There is nothing on the machine except LBP and AF. It still doesn't run? I get the following messages before it stops.
1.) This evaluation version of Booster will expire in 7 days
2.) Error Code: -2147467259 Description: Form was unable to load.
3.) Application Error: Please contact the author of this application
David
Okay, let's back up a little. Something is not installing properly, or you have an older version of Logbook Pro. Can you confirm you are in fact using 1.9.4 of Logbook Pro and you are running the install from the PDA Companions\Pocket PC menu?
I can confirm that I am using 1.9.4 of Logbook Pro and I am running the install from the PDA\COmpanions\Pocket PC menu.
David,
I have nothing else to offer you to try. I'm not sure why your device is not working properly with the software. Have you tried contacting Dell? I know they have had problems with their Axim's and Mobile Windows 2003. Hope you can figure it out, if so, please let me know.
I tried one more thing. I installed LBP without the database and it seemed to run less asking where the database was?
Confirm you followed the install directions to the 'T' in the Logbook Pro Help File and set the proper database path \Program Files\Logbook Pro\Logbook.cdb AND you have Pocket Access enabled in ActiveSync?
Yes I have done it to the T. I recieved no errors upone convertin the database. Can you tell me what files I should see in the directory's?
There are quite a few files associated with AppForge, but with Logbook Pro there are the following:
In \Program Files\Logbook Pro you should see
images (a folder)
lbpro
Logbook
Logbook_Pro
I found all the files and directory's except the image directory. Where exactly should it be and what should be in it?
