Jepp Style Custom Template Help
mickst8ler
Trying to create a Jepp style custom template, I enter a name for the new template as see on the video and the report colums show, howver the name field Under the "Report Designer" (Left side) is so large it appears to be blocking any field parameters. There is just a long while box in the left hand side of the screen with the report name in it, and nothing to modify. Additionaly there is no scroll bar on the screen to get to the bottom of the page. I have tried this is all different window sizes to full screen... no luck
Please Help
--mick
Mick,
Confirm you are using Logbook Pro 1.10.26?
Have you tried creating a new template and starting over?
Last check - minimize all screens so you see your desktop background. Right-click then choose Properties. Click the Advanced tab then the Settings button. Is your Font DPI setting set to "Normal"?
DPI did it thx, I was hoping to be able to reduce the size of the font in the rearks column, but it looks as though it changes all the data fonts...
--mick
