Problem with PalmOS AirlineLog-200xxx.pdb's?
Abe Frohman
I used Filez on the Treo 650 and I noticed that AirlineLog-200608.pdb file properties were incorrect. The properties should be:
Type: data
Creator: APDL.
However, for AirlineLog-200608.pdb the properties were:
Type: APDL,
Creator: data
So, the Palm OS was not recognizing AirlineLog-200608.pdb as a data file (maybe?). I manually changed the file properties within Filez to be correct.
FYI...AirlineLog-200608.pdb was the first new data created since I updated APDL to v6.0.3.
NC Software said:
Hello Abe,
We received your support ticket and will respond once we've investigated the issue.
Thanks. I tested this by creating a fake flight in October (I have no other data for that month). I confirmed that the Creator and Type are swapped in the fake month AirlineLog-200610.pdb.
Thank you for binging this to our attention. It will be corrected in the next Palm release. It does not effect the operation of the software, or the PDA Sync wizard with Logbook Pro.
Fly Safe!
Paul Auman
APDL Development Team
