Pushpins
theKAT
Bloomington, IL
Now that I have seen a couple of example screens in the newsletter and documentation, I'm noticing my results are slightly different.
When exporting flights to Google Earth, I see only the lines of the flights that terminate at the airport. There are no push-pin icons visible.
Windows Vista Ultimate, Google Earth 4.0.2737
Placemarks, tacks, pushpins...whatever. I'm not seeing them.
I did a bit of additional research and I did discover if I create a map without any filters applied, the placemark icons show up on the Google Earth presentation. There is a layer provided to GE called "Route Placemarks", which does not export when using filtered data.
