replacing airport identifiers
bluelake
is there an automated method to replace airport identifiers already in my logbook? Here in northern California there have been some changes to some little airports. I also erroneously logged MANY flights to 2 ZERO 1 (Quincy, CA) and it should have been 2 OSCAR 1 !!!
Thanks.
Hi,
There is no search/replace functionality in Logbook Pro. If you have a lot of replacements, you could export your data (CSV...) use Excel to do the Search/Replace then import back. BACKUP first!!!
I am willing to take my data out and then back into LogBookPro to fix this.. however, does that mean I will need to manually re-create my approaches/holding column? If so, manually changing the airport ID's may be thebetter alternative.
BTW - I am new to this program, but have been a MS Outlook user (and Access developer) for years. Great program you have put together!!
