Resolved Rest Class facility will not stick when creating a tail number
diedrichg
APDL Beta Team
Michigan
v9.1.1.0
When creating a new tail, if you select a rest facility of Class 1 and then go to select the a/c type, when you come back the rest class has reset to Class 3.
Create a new tail #
Select Class 1 rest facility
Select a/c type
Rest facility has reset to Class 3
If you select a/c type FIRST and then select the rest facility, the selection will 'stick'.
You can close this one, it was user error. In the aircraft settings I had the wrong rest facility set for the aircraft type. So when I was creating a new tail number, then setting the rest facility, then selecting the aircraft - APDL was correctly changing the rest facility to what was set in the aircraft settings.
