Transferring Data
Timothy Rowe
I have an old version of Aerolog which uses .DBF files. Can this format be exported to Excel? I do not understand how to do this.
Also, If I am unable to export these files, can I add my total times to Log Pro? How would I go about doing this?
Thank you,
Tim Rowe
Hi Tim,
You should be able to open a DBF in Excel. If you can get your data in a layout similar to the Spreadsheet Style layout you can then save it as a TAB delimited text file and then use the Import Wizard. Five columns are required for an import: Date, Type, Ident, Route, and Duration (or Flt Sim). If you cannot get this to work, ZIP compress your data file (www.winzip.com) and e-mail support@nc-software.com your ZIP file for review.
As for doing a mass transfer, please review this article for more information on this topic. It's essentially the same as transferring from a paper logbook.
