Also having sync problems
bennettrd
DFW
I have the new version of LBP. In the past with single sync I had no problems with the 3 different A/C I fly syncing to LBP. Syncs would set the A/C N# to the appropriate model ie. 135,140,145. Now, with the default set to ERJ-145, thats all that sync to LBP. Is APDL Sync 1.2.0.1 the correct version? How can I resolve the problem?
Hi Richard,
Yes, 1.2.0.1 is the correct version. When APDL is sync'd in, it looks up your N-Number being passed in for a match in the Logbook Pro data then uses that A/C Type. If there is no match, the default A/C Type is used. Can you confirm you had a N-Number logged the same as what is sync'ing in?
I did a lookback and didn't see one. It would be nice if the wizard would just sync what was in APDL and add it to LBP.
Then what is occurring is by design. If the N-Number cannot be found then it uses the Default A/C Type selection. If needed, you can change it, now that the N-Number exists in Logbook Pro the PDA Wizard will pair it properly next time.
