Block Time issue..
dango
Hi all,
New to APDL; loaded my first pairing and days 2 and 3's block time seems fine, but the block time on day 1 is 35+49. I can't figure out whats going on. Day 1, first leg, says OUT at 0715 , IN at 0918, BLK 9+03!! The second two legs add up to 20 plus hours, giving a blck time of 35+ hours on day one.
Does anyone have an idea as to what may be causing this?
dan
Check your timezone settings. Most likely you have your timezones misconfigured.
Eastern -5
Central -6
Moutain -7
Pacific -8
DST gets checked if at anytime during the year the airport uses DST.
Under Prefs...Timezone settings make sure you have DST is in effect unchecked
If the problem continues, please submit a help ticket.
block time issue
Thank you Eric,
-That's exactly what it is...I had the time zones misconfigured
-appreciate your help!!
-Dan
