Cost of transfered log entries?
Kunle
What is the easiest way to have the items we bring over from PPC to PC logbook pro cost calculated? As you probably already know that function doesn't work with the entries that are transfered to the pc version.
Cost calculation based on flight time is only calculated when the Duration value changes. If you want to force it to calc, you'd have to change the duration to a value then back to the original value. The autofill/automation features don't fire on an import, as it may change data you are bringing in, a unwanted side-effect.
