Bug Report Deadhead times update
flysmurf
On a deadhead leg, out/in times would not auto sync. Tried several times and ended up entering them manually. Tried to auto update up to an hour after block in. No luck.
Regular O/O/O/I block times updated normally throughout the day.
I assume the out/in were blank as autofill will not replace an existing value. Also if the entry is locked/closed it won't be touched. Have you tried the autofill now button in the entry itself to command the autofill?
Looks like the leg "closed" out before the times auto updated. When I looked at the leg, it had defaulted to the "scheduled" times instead of updating the "actual" out/in times for the DH. Is there a timeframe the program has to update the times before it closes the leg?
The second screenshot shows the screen just prior to me updating the times manually. I had to "unlock" the screen to update the times.
