Easier Airplane Selection
jnmeade
I have flown many airplanes but now fly three most often. I'd like to bring up the airplane by typing in the airplane type. As it is, I have to choose from a drop down menu, which is awkward. If a drop down menu must be used, it would be nice to be able to position the top few airplanes at the top so I din't have to go through the list to get to the one I wanted.
You can go to options/aircraft and scroll all the way to the right. You will find a column labeled "active". Uncheck any aircraft you do not often use and they will be removed from the dropdown list, leaving only the checked aircraft that you use often.
Those aircraft are not removed from Logbook Pro of course. They can be rechecked and added back to the list at any time.
