The post from 1/16/04 by Chris below regarding Step 6, Bullet 1 solved the problem!!!
At least for me. Thanks.
I realized that '\Program Files\Logbook Pro\Logbook.CDB' did not create logbook.cdb file on my PDA. After clicking OK per last bullet in LBP help file a new window 'Copy and Transfer' opened for about 1 second. Following the steps by Chris the same window took about 20-30 seconds actually transfering the files. Also now on the PDA under \Program Files\Logbook Pro\ there are 3 files (lbpro, Logbook_Pro and Logbook) plus a folder images. Previously the Logbook file was missing so the LBP would not run on my PDA. Hope this helps if anybody has simlilar problem.
I have Active Sync 3.7.1, LBP 1.9.5 and LBP PDA 1.4.
Christopher D. Weston said...
Hello, all! I thought I'd share this with you since I know first hand how frustrating this whole ActiveSync thing can become!
I've found a solution to this problem with ActiveSync 3.7 and 3.7.1, as pertains to Logbook Pro and Pocket PCs (PPCs). You'll have to create a link between your logbook file and your PPC manually. Only one step changes...Step 6, bullet 1, add alternate method to read: Within Activesync right click on the Pocket Access Information Type and select SETTINGS. In the box that opens, click ADD.
At this point you'll be at the same point, but via a different (manual) approach. So, you'll now need to simply accomplish the remaining steps (beginning with Step 6, bullet 2) exactly as written in NC Software's installation guide.
I don't know why this is, but Activesync is a real beast to conquer in many ways.
I also advocate the President's recommendation to ensure your JET4 and MDACs are up to date first.
Happy Computing, and Safe Flying! Or is it the other way around?
CW
