Logbook Pro 1.9 Upgrade
jerryc
I just installed it and yet my version still shows 1.8.9. Is that correct??
I ran the installer from the Upgrade pulldown menu in the program as well as with it not running...
Frankly, I can't find that it did anything.
Am I missing something?
Uninstall Logbook Pro from the Windows Control Panel Add/Remove programs.
Reboot
Reinstall 1.9 that you downloaded. If it doesn't prompt 'Install Logbook Pro 1.9' when you double click the .exe, then you don't have the 1.9 installer. You can download it from www.logbookpro.com and you only need the lbproNoMSI.exe version.
support@nc-software.com
However, I keep my data and Back-Ups in a different folder away from the LogBook Pro folder. I made duplicate copies of the data prior to trashing Logbook Pro. Then, I re-installed using the downloaded updat and started it up....no problem!!
I HIGHLY recommend separating your data out of the application folder.
cheers
Do it right, or don't do it
