Naps/Standups at ASA imported as 2 seperate days
coopervane
In the past, when importing a schedule there was an option for standups. What filter (if any ) will result in the standup being logged as ONE day?
Right now, it is importing my trips as two seperate days
Coopervane,
I don't recall there ever being a specific setting or a filter specifically for CODs. A COD should be imported on two separate days as one normally takes off prior to midnight and then returns the originator in the am.
If you want to have it all on one day you can modify the data in the importer prior to importing to your mobile device.
If you wish, please submit a help ticket along with your trip data and I will look at it further.
I PROMISE you ther was a filter in the old schedule importer for ASA CDO's (not COD's) I used it for YEARS to import CDO'S in the proper format which is listed as the SAME day. Now it doesn't work properly.
The filter name used to be ASA CDO's. I used it for a LONG time so I know it used to be available
[TABLE="class: triptitle raised"]
[TR]
[TD="align: center"]AWD I4172 CRJ - 7021061 Kelly Kendrick - IAD CRJ CA[/TD]
[TD="align: right"][TABLE="class: MenuTrip_2"]
[TR]
[TD][TABLE="class: menubutton MenuTrip_4"]
[TR]
[TD]
[/TD]
[/TR]
[/TABLE]
[/TD]
[TD][/TD]
[TR]
[TD]
[/TD]
[/TR]
[/TABLE]
[/TD]
[TD][/TD]
[TR]
[TD]
[/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[/TABLE]
[TD="class: daystart, colspan: 15, align: left"] Monday 06-11-2012 Report: 21:10[/TD]
[TD="class: flightheader, align: center"][/TD]
[TD="class: flightheader, align: center"]Flight[/TD]
[TD="class: flightheader, align: center"]Tail[/TD]
[TD="class: flightheader, align: center"]A/C[/TD]
[TD="class: flightheader, align: center"]Orig[/TD]
[TD="class: flightheader, align: center"]Dest[/TD]
[TD="class: flightheader, align: center"]Dep[/TD]
[TD="class: flightheader, align: center"]Arr[/TD]
[TD="class: flightheader, align: center"]Pax[/TD]
[TD="class: flightheader, align: center"]Block[/TD]
[TD="class: flightheader, align: center"]Credt[/TD]
[TD="class: flightheader, align: center"]Miles[/TD]
[TD="class: flightheader, align: center"]BurnAv[/TD]
[TD="class: flightheader, align: center"]Turn[/TD]
[TD="class: flightleg, align: right"] 1. [/TD]
[TD="class: flightleg, align: center"]UA5709[/TD]
[TD="class: flightleg, align: center"][/TD]
[TD="class: flightleg, align: center"]CRJ[/TD]
[TD="class: flightleg, align: center"]IAD[/TD]
[TD="class: flightleg, align: center"]ROA[/TD]
[TD="class: flightleg scheduledtime, align: center"]22:10[/TD]
[TD="class: flightleg scheduledtime, align: center"]23:05[/TD]
[TD="class: flightleg, align: center"]__[/TD]
[TD="class: flightleg scheduledtime, align: center"]0:55[/TD]
[TD="class: flightleg, align: center"]177[/TD]
[TD="class: flightleg, align: center"]1745[/TD]
[TD="class: dayend, colspan: 15, align: center"]Hotel: Hyatt Place Roanoke Airpo (540) 366-4700 Layover: 6:55[/TD]
[TD="class: daystart, colspan: 15"] Tuesday 06-12-2012[/TD]
[TD="class: flightleg, align: right"] 2. [/TD]
[TD="class: flightleg, align: center"]UA5747[/TD]
[TD="class: flightleg scheduledtime, align: center"]06:00[/TD]
[TD="class: flightleg scheduledtime, align: center"]07:03[/TD]
[TD="class: flightleg scheduledtime, align: center"]1:03[/TD]
[TD="class: flightleg, align: center"]1849[/TD]
[TD="class: flightleg, colspan: 9, align: right"]Day Total:[/TD]
[TD="class: flightleg scheduledtime, align: center"]1:58[/TD]
[TD="class: flightleg scheduledtime, align: center"]5:04[/TD]
[TD="class: flightleg, colspan: 3, align: center"]Duty: 10:08[/TD]
[TD="class: dayend, colspan: 15, align: left"]
[TD="align: left"] Release: 07:18/12[/TD]
[TD="align: right"][/TD]
[/TD]
[TD="class: triptotals, colspan: 15"] Totals: Report 21:10/11 Release 07:18/12 Block 1:58 Credit 5:04 TAFB 10:08[/TD]
Key: Scheduled; Estimated; Actual; Overridden;
[TD="class: triptitle, colspan: 4, align: center"]
[TD="align: center"]Crewmembers for Each Flight[/TD]
[TD="class: smalltext, align: right"]* First Flight
Checked In[/TD]
[/TD]
[TD="class: crewtitle, align: right"][/TD]
[TD="class: crewtitle, align: left"]Captain[/TD]
[TD="class: crewtitle, align: left"]First Officer[/TD]
[TD="class: crewtitle, align: left"]Flight Attendant[/TD]
[TD="class: crew2, align: right"] 1. [/TD]
[TD="class: crew2, align: left"]*7021061 Kelly Kendrick[/TD]
[TD="class: crew2, align: left"]*7022916 Peter Cascone[/TD]
[TD="class: crew2, align: left"]*7020650 LaNandra Carpenter[/TD]
[TD="class: crew1, align: right"] 2. [/TD]
[TD="class: crew1, align: left"]7021061 Kelly Kendrick[/TD]
[TD="class: crew1, align: left"]7022916 Peter Cascone[/TD]
[TD="class: crew1, align: left"]7020650 LaNandra Carpenter[/TD]
The filter name used to be ASA CDO's. I used it for a LONG time so I know it used to be available. Here is the response from Neal in 2004
Try the filter titled "Generic Crewtrac Bidlines (PDF) - Continuous Duty"
And this worked FOR YEARS....I USED THIS FORMAT FOR 7 YEARS. Don't tell me I am mistaken. At least admit the filter is no longer available or has changed. I purchased the schedule imported with the belief that if I paid for it, it would be at least as good as the free version I have used for 7 years.
Here is the format of the trip
[TR]
[TD="align: center"]AWD I4172 CRJ - 7021061 - IAD CRJ CA[/TD]
[TR]
[TR]
[TD]
[/TD]
[/TR]
[/TABLE]
[/TD]
[TD][/TD]
[TR]
[TD]
[/TD]
[/TR]
[/TABLE]
[/TD]
[TD][/TD]
[TR]
[TD]
[/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[/TABLE]
[/TD]
Checked In[/TD]
[/TD]
[TD="class: crew2, align: left"]*7021061[/TD]
[TD="class: crew1, align: left"]7021061[/TD]
CDOs should be 2 days, not 1. The only reason they were 1 is because the old APDL software would overwrite days.
A filter that doesn't separate days would cause problems for people that use Logbook Pro.
Just simply change the 2nd day in each of your pairings to match the first date. Then your trip will import as 1 day if you so wish. Or continue to use the older versions....
