PDA Wizard not syncing all data.
Skyking-1
Having more problems. I am using APDL on my Treo 700W / WM5.0 and Logbook Pro on the desktop. Every time I use the PDA Wizard to sync my latest flying to LBP, only 1 days flying out of 4 transfer. Mostly just the last day. I try to sync numerous times being succesful on some occasions but frequently having to manually put my times in. I am current on all versions.
Please help,
Jeff
FYI, I have read the forum and "Generate APDL Reports" is NOT checked.
Hello Jeff,
Please ensure you have the latest versions of our software as listed here. When syncing APDL-Pocket PC edition, first tap (S) to force a save of your data, then tap menu Options...Exit to completely close APDL. After APDL is saved and closed, run the PDA Wizard again.
If you experience any other difficulties as you inquired after the procedure above, please submit a support ticket and include the log file saved from the PDA Wizard run.
APDL Reports is fixed in 1.10.24, you can run them now.
