snyc multiple a/c per day
m4j2t
I fly up to 8 legs per day in two or three different a/c. I want to continue logging daily (NOT by leg) because I've been doing it that way for years by hand. When I use single sync for apdl to lbp it only inputs one a/c in the a/c column. Is there any way to ammend this?
ps where is the datebook -- I can't find it
ipaq 3850 w mobile 2002, apdl 6.0.1, lbp 1.9.9
blueskies
Currently SingleSync is limited to one default A/C Type. The APDL Development team is currently working on an update to SingleSync with a method to identify your prior N-Numbers in Logbook Pro and subsequently select the corresponding A/C Type, hence this should solve this issue.
Datebook functionality is not compatible with Pocket PC versions, only Palm OS (non-cobalt processors, aka Treo's) at this time. We are considering ways around this limitation in the Pocket PC for future versions.
We hope you enjoy APDL and Logbook Pro.
