Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Logbook Pro Mobile for iOS and Android get major updates and now available on the Apple App Store and Google Play. Be sure to update at your earliest convenience. For details click here.
Wondering if there are any SW pilots using Logbook pro who can explain how to easily import from CWA or the Swapa logbook without buying Wbid or. Moostro. Thanks in advance!
yes, you can import your past flying from SWAPA into Logbook Pro
Download & save your flying from SWAPA in the CSV (Comma Separated) format. This is an option in a drop down menu in SWAPA. Make sure you are using your actual times as well.
Start Logbook Pro
Select FILE..IMPORT WIZARD and follow the prompts
You may also want to setup and use autofill for your Cross Country and PIC or SIC times as well during the import.
For more on the import wizard and autofill systems please reference video 9000 and 2100 respectively at the link below:
