Unable to synch data entered on PDA
yankee clipper
recently installed and registered my Logbook Pro PPC companion (v1.10.15). The laptop runs Logbook Pro 1.10.24. Active synch is v4.0
Data entered into the PPC doesn't transfer to the PC during synching, and is deleted off the PDA/PPC.
Am I doing sth. wrong?
Heeeeeeeelp.
Yankee clipper
How do I uninstall Logbook Pro (PC)? via the Add/Remove feature in windows?
The laptop is running Windows XP Pro.
To uninstall the Pocket PC Companion from the PDA/PPC can I use the instructions from the thread below?
When I installed the PPC companion, I downloaded the version with the .NET Compact Framework included. Must I reaccomplish this aspect again as well?
06-04-2006
http://www.logbookpro.com/forums/member.php?u=9
NC Software vbmenu_register("postmenu_8545", true);
Developing for the Future
/My Documents/Logbook Pro
/Program Files/Logbook Pro
After that is completed AND you verified the .NET COMPACT Framework v2 is installed on your device (see this article for more info) reinstall the latest download of the Logbook Pro Pocket PC Companion from this web site. After this is completed and you confirmed also that Logbook Pro for Windows 1.10.23 is on your PC and you also have the Microsoft .NET Framework 1.1 installed on your PC, start then close Logbook Pro, then launch Logbook Pro on the Pocket PC.
__________________
-Visit our Online Store for Sales Information
-Submit support tickets here
-Search the forums and Knowledgebase (KB) for answers to common questions
-Are you using the latest version? Check now
:uhh: Any gotcha's during this uninstall and reinstall process?
yankee clipper
