Importing and Flight Numbers
H13
I am using the evaluation version.
1. Importing
When either using a Tab or Comma Delimited file, after selecting "import destination" colums, I cannot select "Import" as it is grayed out. Is this a lmiitation of the evaluation version? I removed all but threeflight so not to interfere with the 50 flight limitation.
2. Ailrineloogbook
Does Logbook Pro allow for the display of Flight Numbers? and/or Imported Flight Numbers fromAirlinelogbook?
Rob
Solved issue #1 by watching video, 'five items required'.
2. I realize now that there is a custom field, is it possible to import the flight numbers into that custom field from Airlinelogbook?
I'm not familiar with the import process from APDL, please contact support@airlinelogbook.com. If you were using the Import Wizard from the Logbook Pro side, then yes, you could import to your custom fields as well.
