position category
bluelake
I am only going to be logging SIC flying for the foreseeable future.
I have removed the CA-XXX positions from appearing in the popup lists under SETUP.. POSITION CATEGORIES. Still, when I make an entry into a logpage the default entry is CA-PNF-DAY. Is there a way to change this to something more appropriate to an FO position?
Thanks, Dean
Thanks, Dean
DEAN,
Here is a work around for the problem you are experiencing. You can rename the CA-PF-DAY etc to FO-PF-DAY, etc and then it will default to what you want.
When you upgrade to CA you should reset the position categories by pressing the default button.
