The import button wont activate
angelicm3
Hi,
I work for Skywest and they have something called etrip. on etrip I have the option of transfering the information in many different formats like .ics .cvs .txs .vcs
I use the import wizard to try to transfer what I flew and what is shows on etrip. but at the last step on the import wizard the import button does not work.
I included a picture of the problem by using the windows screen capture. and what etrip is
I wonder what is happening!!!!!
In order to use the Import Wizard you must have the minimum five columns mapped: Date, Type, Ident, Route, and Duration. Once you set the last mapping, tab (or shift+tab) to move off of the last column and the import wizard will determine if you have the required columns, if so, enable the Import button.
Thank you, it works now. I just noticed I didnt have the last requirement marked like the duration. now it works great!!. this program is the best !!!!!!!!!!
