added custom time field wont appear in spreadsheet
Bushwick
I added 2 custom time fields to my logbook.
I went to options\ custom\ timefields
I added turbine in slot #1
I added night x.c. in slot #2
these custom fieldsdo appear in the windows style logbook but i find it very clumsy
they do not appear in the spreadsheet style logbook
i went to options\ flightlog\ config display and clicked the little boxes next to my time fields reset the spreadsheet and it still does not appear even after restarting the program and reseting the log several times
any ideas??
Cheers
Dave
Dave,
Make sure they are not in the far right, i.e. scroll all the way over and also check that the column width of the column isn't shrunk down. If you notice the right edge of any columns are heavier then others, it's probably at minimum width. Resetting the Spreadsheet layout should resolve it. Another thing you can try. Leave the spreadsheet style entry area open, then go into options. Put a space on the end of the two custom column labels, close the Options. Then go back into the Options and remove the trailing space. See if the spreadsheet style area updates.
It seems to be working not sure what did the trick but the new colums are visable on the spredsheet.
Dave
