Potential Buyer with a couple of questions:-
Steve Mackay
I'm working my way through my ratings and I figure I need to get my logbook in electronic format for all the reasons I am sure everyone else needs it. I downloaded the demo and have been messing with it, but i have a couple of questions:-
1. Is Logbook Pro compatible with windows XP?
2. Is there a way to keep track of my instructor costs. ie my instructor charges $35 per hour so I need some way of multiplying my instructor rate by my flight time in the same way flight cost is calculated. How can this be done?
3. Can I have 2 different costs assigned to 1 aircraft? For instance to rent a C152 used to be $55/hr but this summer, lets say 6/1/2002, they put up the price to $60/hr. Therefore I want all C152 costs pre 6/1/2002 to be calculated using $55/hr and anything after that date to be calculated using $60/hr. Can this be done?
I think that is about it for now. It looks a nice piece of database programming from what I can see.
Steve
Hi Steve,
To respond to your questions:
Yes, it sure is.
You can certainly keep track of the expenses by creating a Custom Expense field in the Options...Custom area. However, there is no way to auto-calculate this figure within Logbook Pro.
Not for auto-calculations, at this time you can only assign one cost/hr for calculations at the time of flight entry. The flight cost is only calculated when a duration value is set/changed, therefore you cannot flow prior values or update existing values if you change the price. What you could do is export your data to a program such as Microsoft Excel, do the formula magic, then import the data back into Logbook Pro.
Hope this helps!
